Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
578 Questions View all
iMac powers up but only to sign on screen, but I cannot select start.
Late 2014 IMAC worked fine but now it powers on, goes to start but I cannot select start. Keyboard & mouse plugged in, tried bluetooth mouse just to get to start but does not connect. Is there anyway to boot up
Add a comment
1 Answer
Do you hear the fan or startup Bong?
Just with the limited information I’m guessing the power supply has failed. But that’s just a guess! You really need to dig a bit deeper. Did you check the outlet and the power cord, try another outlet and cord. Did you have a lightning storm or other weather event that could have caused a power surge (lights flicker or anything else stop working). I would get a simple outlet checker to make sure the outlet is correctly wired. You might want to check your buildings ground and get a good surge suppressor to protect your equipment if you discover your at risk.
Add a comment
Add your answer
Kristie Mehlbaum will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 17
