Would like to change my motherboard
My msi stealth gs75 9sg graphics card died. In device manager it has a code 43 and a nvnvlddmkm blue screen error code along with a SYSTEM_THREAD_EXCEPTION_NOT_HANDLED blue screen error. I did everything possible including the DDU.
I want to know if I can swap my motherboard with the exact same specs and motherboard set up. On ebay there are some exact motherboard models. I wanted to know if it is safe and okay to replace my motherboard?
Laptop specs
Model: Msi Stealth gs75 9sg
Gpu: Rtx 2080 max q
Cpu: i7 9750h
Ram: 32gb ddr4
Add a comment
1 Answer
@kentracerd38110 yes, it is absolutely okay to switch like for like. If you found a motherboard with the same specs and numbers as your, it is okay to switch it.
Add a comment
Add your answer
KenTracer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 80
