Power Button is staying an Amber Red with plug and without
[While pressing the power button it will not switch over to the white and show the battery level. Even if you reset the speaker the power button will go dark, then when plugging back in the power button goes back to amber red. Also will not even show charging. Even if you don't plug in and press the power button it goes to Amber color.
Yes Battery is good and I even swapped out for a new one and same results.
Here are pics
Score 1
Add a comment
1 Answer
Chosen Solution
@chris58709 anything happened to it prior to? What have you checked? from the brief description it appears that this is focused mostly on the power board. If you can, post some good pictures of all of the boards with your Question. Let's see what the battery looks like as this could be at fault as well. Adding images to an existing question
Update (12/24/23)
@chris58709 could just be my old eyes but what you got going on here?
Score 1
Add a comment
Add your answer
Chris will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 55
All Time: 276
