Released September 21, 2018. Models A1920, A2097, A2098, A2100. Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray. (Pronounced "iPhone 10 S.")
370 Questions View all
iPhone XS Shuts down when plugged in
My i phone xs shut down when i pluged in lightening cable or earphone and screen is locked. but if i use the phone it will not restart . It happen only in lock screen . Panic full report also showing i2c0
Add a comment
1 Answer
Most Helpful Answer
Based on this panic log and your symptoms this sounds like a new charge port assembly is in order. The panic itself refers to ad5860, which is the chip that controls the vibration motor, and signals travel through the charge port assembly. Especially given your other symptoms which seem to revolve around the charge port, I think that's a good first step.
Replace a lightning connector, microphone, and flex cable compatible with the iPhone XS. Fix problems with charging, USB device connectivity, and audio recording. Part #821-01363. Image
Product
iPhone XS Lightning Connector Assembly
$24.99
Score 2
Add a comment
Add your answer
Its Sunny 3309 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 94
