My fingerprint is not working? What to do?
My fingerprint is not working and fingerprint option is removed from everywhere first gives me warning then it's removed fingerprint
Get quick access to guides, parts and answers for your devices
If the fingerprint option works OK when starting and using the phone in safe mode then usually a downloaded app¹ is the cause of the problem.
The trick is to find out which one.
You will need to uninstall each downloaded app, one by one and test the phone in normal mode between each uninstall to check if it works OK. When it does then the last downloaded app that was uninstalled was the culprit.
A downloaded app¹ is one that you downloaded and installed on the phone and wasn't pre-installed on the phone when you first got it.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 19
All Time: 544
2 Comments
Hi @ansarikashaf,
Does the problem also occur when starting and using the phone in safe mode?
by jayeff
No, My phone is fully functional in warranty period after just 10 days of warranty it removed fingerprint.
Please give me solution how to repair it ?
by ansari kashaf
