Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
102 Questions View all
How do I fix black screen?
Here are the symptoms:
-When you press the power button, the screen flashes white twice, then stays black. Otherwise, everything else starts up normally with the chime and hard drive sounds, etc.
-Shining a flashlight to the screen shows it still works (just no backlight?)
-I've reset the PRAM, no go
-I've replaced the inverter board but that didn't work
-It does work with an external monitor attached
I am currently running an extended Apple hardware test to see if it brings up anything specific.
Could something on the logic board be bad?
Bad CCFLs?
1 Comment
The hardware test did not find anything. Bummer.
by
Add a comment
1 Answer
Chosen Solution
It's the screen connection to the board, screen or video card
Here is the screen guide, take it apart and check the screen connector, if nothing, try a a screen
iMac Intel 20" EMC 2266 Display Panel Replacement
If not, it's the video card or logicboard(I think this model has a MXM card)
I do not know much about the video card built onto the board or a seprate card, but I know this, if it's a ATI(AMD now) or NVIDIA, it's probably on a separate board, if it's intel, no, on the logicboard itself, you will need to take your iMac apart to know for sure about this
Here is the GPU swap guide
iMac Intel 20" EMC 2133 and 2210 Video Card Replacement
iMac Intel 20" EMC 2266 Display Panel Image
Guide
Difficulty:
Moderate
iMac Intel 20" EMC 2133 and 2210 Video Card Image
Guide
Difficulty:
Moderate
1 - 2 hours
1 Comment:
thank you nick, i really appreciated you, its also solve my problem
by
Add a comment
Add your answer
mike will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 2,477
