Repair guides and documentation for the Google Pixel 6a with 5G smartphone. Released in July 2022.
48 Questions View all
Yellow display due to missing SMD resistor. Resistor value WANTED!
I have a yellow display and it turned out that an SMD resistor on the motherboard had broken out. Unfortunately I don't know the resistance value and I would be super grateful if someone could measure this resistance value. Please write whether you measured the resistance when installed or removed.
The resistor is located directly on the mainboard just below the connector for the display and is covered by this connector as long as it is plugged in.
Thank you very much and Christmas greetings 😊
Score 1
Add a comment
1 Answer
Most Helpful Answer
I measured the resistance value and size on a second phone. It is a 0 Ohm resistor in a 0402 package. After replacing the resistor the Display is functioning without the yellow cast. :D
Score 2
1 Comment:
Hi Fabian, my pixel has a similar issue. Could you please share a link where I can buy the resistor? Thanks!
by
Add a comment
Add your answer
Fabian Popp will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 107
