PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
Wired Connection not working
I have a ds4 controller that works via Bluetooth but is unable to work with a wired connection to the PlayStation and pc. I figured the port wasn’t working so I decided to swap the port with another controller whose analog sticks are broken. This new port works perfectly but when making the swap, the controller still doesn’t show up as a wired connection.
I can provide pictures or answer any questions to help troubleshoot this issue. At this point I’m more intrigued on how to get it working than anything else. Any hardware that I should be looking at that could be the culprit here?
Worth noting: Since the wired connection wasn’t working, i decided to download ds4windows to see how the Bluetooth connection to the pc would hold up vs input lag. During this process, I was changing settings on ds4 along with the controller device in my pc control panel. I disabled a driver that a video recommended during this. Not sure if I might have done something to alter the controllers ability to recognize the wired connection.
Thank you!
Update (01/07/24)
This has been solved. Needed to get the correct usb connection for the controller model. Ordered this online and now the controller works fine.
Add a comment
Chosen Solution
Score 1
Add a comment
Most Helpful Answer
@lincolnabe0978 copy your update as an answer, then accept it. That way we know it has been resolved.
Score 1
Add a comment
Add your answer
Brad Riley will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 107
All Time: 1,935
