Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
576 Questions View all
GPU upgrade/replacement, SSD upgrade and CPU upgrade
Hi there!
I have a late 2015 iMac 27" and I was wanting to do a few things to it. Its current specs is the base model
What is the max gpu I could put inside the iMac even if I have to modify it?
Would I have to install drivers and how would I do it? Could I put an NVIDIA card inside the iMac?
Secondly I want to put an SSD inside it. Is it just as simply as placing a 3.5inch ssd into the SATA port or is there something else I have to do as well?
As I cherry on the top, what is the most powerful cpu I could put inside it?
Add a comment
1 Answer
The GPU chip is soldered in unlike the older MXM models in the 2011 and older iMacs. So, you would need a logic board swap out to get the high end Apple offered. Not really worth it.
You have two options the SATA port as well as a custom blade SSD refer to these guides
As far as CPU you are limited to what Apple offered for this series 4.0 GHz Core i7 (I7-4790K)
iMac Intel 27" Retina 5K Display Hard Drive Image
Guide
iMac Intel 27" Retina 5K Display Hard Drive Replacement
Difficulty:
Moderate
1 - 2 hours
iMac Intel 27" Retina 5K Display Blade SSD Image
Guide
iMac Intel 27" Retina 5K Display Blade SSD Replacement
Difficulty:
Difficult
2 hours
Add a comment
Add your answer
Z S will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 18
