Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
376 Questions View all
Shutting down while plugged into power supply
Hi. I just got my iPhone XS Max and whenever I plugged it into power supply it charges for some seconds and the next thing me checking it back it’s at switched off. That means it’s automatically switches off itself.
If I then unplugged the charger it will then power on it self. Then when power on itself I later plug it into power supply and continue using it while charging and no problem but if I just drop the phone down for it to charge it will still power off it self again.
Add a comment
1 Answer
The main problem that you faced is while not keypad is locked you can use it for a long time but when you leave the iPhone for something it shuts down. That is the issue that I faced and after hours of research, I found the solution there is a problem with the circuit that helped me in that case you can also try once.
1 Comment:
did u changed the circuit? plz help me im facing this issue
by
Add a comment
Add your answer
Sirojuððin Salau will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 118
