WiFi saya tidak mendeteksi adanya jaringan WiFi di sekitar
Saat saya menyalakan WiFi di ponsel saya, WiFi di sekitar tidak terdeteksi,saya sudah coba dengan Scan QR untuk Menyambungkan WiFi, meskipun saya sudah coba berkali kali tapi tidak pernah bisa terhubung , sedangkan di ponsel lain WiFi terdeteksi dan terhubung, baik di sambungkan dengan Password ataupun Scan QR,
ini adalah gambar di mana tidak ada satu pun jaringan WiFi yang terdeteksi di sekitar ponsel saya,jadi apa yang harus saya lakukan?
Google translate:
My WiFi does not detect any WiFi networks nearby
When I turn on WiFi on my cellphone, WiFi around it is not detected, I have tried to scan QR to connect WiFi, even though I have tried many times but can never connect, whereas on other cellphones WiFi is detected and connected, either connected with a password or Scan QR,
this is a picture where not a single WiFi network is detected around my phone,so what should I do?
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hi @sitiaisyah
Does the Bluetooth work OK?
Try using the phone as close as possible to your home network router i.e. <10cm and check if the WiFi network is detected.
If you can detect and connect to the network then there may be an antenna problem (loose?) with the phone.
Here's an image taken from this teardown video showing the antenna connections in the phone..
(click on image)
If it still doesn't detect the WiFi network and if the BT doesn't work either there may be a problem with the WiFi/BT IC on the systemboard.
Score 2
Add a comment
Add your answer
Siti Aisyah will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 49
All Time: 194
