Repair guides for the Samsung Galaxy Tab A series of tablets. Released in 2015.
483 Questions View all
Why is my Samsung tablet showing the battery sign when plugged in but
So basically I would put my tablet on charge and I would press the power button and it would show the charging signal on it but when I take it out it won’t turn on or even show that I need to charge it
Add a comment
1 Answer
@disha43291 that is what can happen when your battery no longer takes a charge. Your tablet shows the charging symbol because it is trying to charge the battery, but once you disconnect, it'll turn off since the battery is unable to hold a charge. I would suggest you start of by replacing the battery, then re-evaluate.
You did not tell us what exact model your Tab A is so we can't help you with the battery replacement.
Add a comment
Add your answer
Disha will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 57
