The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1191 Questions View all
I bought broken Mac and I need to repair it.
Hi forum!
I bought totally broken MacBook and i want to repair it as much i can and give it a second life...
The problem is: Theres totally broken display, but you can see thats powered on.
It will die without chargering (probably broken battery..)
HDMI does not reacting - I cant use it atleast with TV.
Trackpad is broken too (its my smallest problem)
So i want your advice: will it be better if I fix it completely? Or should I just focus on hdmi?
I need to know what parts to fix to make it worthwhile.
Thank you so much!
Add a comment
1 Answer
Chosen Solution
Personally I would focus on getting HDMI and trackpad to work before you touch the display. To get HDMI to work you may need to boot into clamshell mode which is when you have external keyboard, mouse and AC adapter with the lid closed as these machines won’t have display out on HDMI when lid is open until after boot and graphics is initialized. More than likely you just need a new trackpad as that is a fairly common issue on these Mac’s. The displays are pretty expensive so that would be the last thing I would get after verifying full functionality.
Score 1
1 Comment:
I´ll try!
Thank you so much.
by
Add a comment
Add your answer
Robin Horáček will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 34
