Repair information for Whirlpool dishwashers.
158 Questions View all
Whirlpool Dishwasher not Draining
Hi! I have an old school Whirlpool Dishwasher Model DU8500KB-0 that is all the sudden not draining. I cannot find a manual on it to figure out where the filter and drain are to inspect. Everything else working fine.
Update (01/10/24)
See picture
2 Comments
Hi @dishproblem,
Please verify the model number as searching online for the model you posted gives no results?
The closest model number is DU8500XB-0
by
DU8500KB-0 - serial
FD25 66489 - model
DU8500X - stock
by
Add a comment
1 Answer
Most Helpful Answer
Hi @dishproblem
Your dishwasher model is a DU8500XB0 and not a DU8500KB0. There's a crease in the label passing through the X in the model number, so it appears as though it might be a K, but when zoomed in you can see it isn't. (see image below)
Can you hear if the drain pump motor is operating (or trying to operate) when the dishwasher should be draining?
There is no drain filter in the dishwasher so if you can hear the pump operating and if the water is not draining through the drain hose into the household drainpipe connection (normally the dishwasher drain hose is connected to the drainpipe under the sink in the kitchen) then usually the most common reason for this is either the drain pump is faulty i.e. broken impeller or there's a problem with the check valve
The supplier links are only to show where the parts are located, have videos that show how to remove/replace them if they're faulty and also show the manufacturer's part number for the part.
If a part needs replacing, search online for the manufacturer's part number only (not the linked parts supplier's part number) to find suppliers that suit you best.
(click on image)
Score 1
Add a comment
Add your answer
Deidre will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 23
All Time: 87
