Repair information for Whirlpool dishwashers.
158 Questions View all
quiet partner III MOD GU3200xtpq3 no longer turns on at all,
Hi,
my dishwasher no longer turns on at all, no buttons light up or work. I have already tried the breakers, the electrical plug everything is ok. what should I do?
I have a whirpool gold series quiet partner III MOD GU3200xtpq3
Add a comment
1 Answer
Most Helpful Answer
Hi @florencemadau
There's a non resettable thermal fuse¹ in the dishwasher, that if blown disconnects the power to the dishwasher.
It usually blows due to the dishwater becoming overheated so if it is blown you will have find out why this occurred. There's a high limit thermostat¹ that is supposed to operate to turn off the heater if the temp gets too hot so perhaps this may be the problem.
Here's the tech sheet for the dishwasher that will help. Once you have replaced the thermal fuse, run the diagnostic tests as shown in the tech sheet to check that it works OK.
¹ The supplier links are only to show where the parts are located, have videos for how to replace them if faulty and also show the manufacturer's part number for the part. If any parts need replacement, search online for the manufacturer's part number only to find suppliers that suit you best.
8193762 - Whirlpool Dishwasher Thermal Fuse Image
Product
$37.99
WP661566 - Whirlpool Dishwasher Thermostat Image
Product
$25.99
Score 1
Add a comment
Add your answer
florence madau will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 29
