Released September 21, 2018. Models A1920, A2097, A2098, A2100. Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray. (Pronounced "iPhone 10 S.")
405 Questions View all
Touch screen not working
iPhone XS I changed the battery and I don't know how I did it in the meantime that reassembled the touch screen no longer works, do you have any tips to check where the problem may be? I checked the connectors my pure was the flat cable but it looks whole
Add a comment
Most Helpful Answer
Generally there aren't too many explanations for why the touch screen fails when some other repair is being done. The digitizer cable may have been torn, the connector damaged, or simply just not plugged in completely.
Outside of the front sensor connector at the top of the screen, the other two connectors are for the OLED display and the digitizer. If the touch screen isn't working then you'll need to focus on this connector.
First thing to do is to open it back up and check the connector on both sides, the motherboard and the flex cable. Use a magnifying glass and a bright light and check for missing or broken pins. Check the logic board around the connector for any missing components; sometimes they can get knocked off in the process of trying to plug those connectors in.
If you find any issues with the pins, bent ones can sometimes be straightened with some fine tip tweezers, while missing ones are more problematic. If the flex cable connector is damaged you can simply replace the screen, but if something's wrong with the motherboard connector you'll need someone experienced in microsoldering with a hot air station to fix it.
Assuming you haven't found anything wrong with the connectors, go over the flex cable with a fine tooth comb looking for any kind of damage like tears or excessive bends that have cracked the circuit traces. Again, the fix for that would be a new screen.
Once you get to this point, clean both sides with 90% or higher concentration isopropyl (rubbing) alcohol. Reassemble the screen, paying special attention to the note regarding plugging in those FPC connectors.
There are a couple of notes to pay attention to specifically regarding the digitizer connector that bear keeping in mind as well.
If it still doesn't work, then about the only other thing you can do is to go ahead and replace the screen in hopes the problem is on the screen itself and not on the motherboard.
Hopefully something in here will help. Give these suggestions a try then come back and let us know what you found and we'll see if we can figure out what the next step should be if needed.
Update (01/14/24)
Oh, and just to address your comment, if the digitizer is damaged, then the only solution is to replace the screen. It requires specialized equipment and expertise to successfully separate the OLED and the front glass digitizer, then more equipment to bond a new digitizer to the OLED. It's not even close to being cost effective to try and do that yourself, and the chance of success isn't all that good anyway.
Score 1
Add a comment
Try replacing the LCD screen
1 Comment:
Of course this is the most obvious solution, but since the screen turns on I just wanted to understand if it was possible to repair the touch without changing the screen out of curiosity, thank for the help 😄
by
Add a comment
Add your answer
Nicola conti will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 54
