Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
685 Questions View all
Torn black film on logic board
While trying to remove the battery to replace it, I tore the black film that's on the logic board, leaving an approx 1 inch tear exposing some kind of silver cover just underneath. I just wanted to know if this is something that would require a replacement or if it should be fine as is.
I did some reading around and found that tears to the film on the wireless charging coil underneath the battery weren't much of an issue, and I'm assuming that the film on the logic board is the same kind of graphite shielding as on the wireless charging coil.
I have some electrical tape on standby if that can be used to cover the tear. Any help is greatly appreciated!
Add a comment
Chosen Solution
The black tape (called Graphite Tape) is for heat transfer and acts like a heat dissipator. The silver metal shields are EMI shields.
Should be fine without it, but if you're worried you can order the tape online.
Score 1
Add a comment
Most Helpful Answer
its just like a thermal tape it will be fine without it
Score 1
Add a comment
Add your answer
Tyler Drake will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 65
