Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
784 Questions View all
seeking enclosure for SSD from MBP early 2011?
Hello - I have an early 2011 MBP that has a 1tb ssd upgrade, I would like to remove the ssd and use it as an external drive, but not finding a compatible enclosure, is there one? I found this but it seems to be perhaps only for the SATA drive being removed in the upgrade... MacBook and MacBook Pro (Non-Retina) SSD Upgrade Kit --thanks much!
MacBook and MacBook Pro (Non-Retina) SSD Upgrade Kit Image
Product
$69.99
Add a comment
1 Answer
Chosen Solution
The case is designed for a 2.5” SATA drive not the blade SSD if your system has that.
Score 1
1 Comment:
oops - Thanks Dan, I thought this one was an SSD but just pulled it out and it is a SATA. so perhaps it will work?
by
Add a comment
Add your answer
Allie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 40
