Released in November 2020, the 13" MacBook Pro features Apple's Arm-based M1 SoC with both an 8-core CPU and 8-core GPU. (Model A2338 / EMC 3578 with two Thunderbolt 3 ports)
116 Questions View all
Are A2251 and A2338 screen Compatible?
Hi, my MacBook’s screen got cracked, and I’m searching for a replacement. However, every screen I’ve seen on eBay is labeled as A2251 And A2338. I’m unsure if it will work for me, considering one is for an Intel Mac and the other for Apple Silicon.
Add a comment
1 Answer
To be clear the A2251 is a four port Intel based system and the A2338 is either the M1 or M2 system.
Sadly, Apple alters things between the series that prevent using older displays on newer systems.
The reason you can’t find a display for your M1 system is Apple has now entered into the open parts supply! While that is good for thoughts who want real Apple parts that are fresh. Apple also has tightened things require calibration via a pay-walled tool. While a used screen can be used you will loose TrueTone services. Review the iFixit guide here MacBook Pro 13" Two Thunderbolt Ports Late 2020 Display Assembly Replacement
So you’ll need to visit Apples Self Repair Store to get the new display.
Add a comment
Add your answer
Santiago U will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 28
All Time: 105
