Repair guides and support for USB flash drives, also known as jump drives, USB sticks or thumb drives.
52 Questions View all
USB Not detecting to pc
When I connect my USB flash drive to my PC, it doesn't show any data. "Please insert a disk into a USB drive (D:)" is the message that appears.
Score 2
1 Comment:
Hi @rajeshgore43720,
Does the USB flash drive work OK when connected to other computers?
by
Add a comment
1 Answer
I've had this before, when the USB was formatted as a Linux install. Most likely that the drive isn't formatted correctly. In Windows 10 File Explorer, you should be able to right click on the drive and format it to ExFAT for general file use (this will erase what is on it). This could also be happening due to damage to the drive. It would help to know what the drive was used for before this happened.
Add a comment
Add your answer
Rajesh Goregaonkar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 72
