no envia video la pantalla
enciende pero no da video al monitor
@hectorcede40839 first we need to know how you know that it has turned on. Let us know what the power LED does. Once you made sure it is on but not displaying anything, we need to know if you are using a dedicated video card or if your are using the motherboard integrated video card. Let us know how much memory your computer has and what you have checked. We need to know if you are certain that the monitor isds working. which exact model you have.
If your computer indeed turns on and functions properly, then the issue is your video output (if your monitor is working). This could be an issue with the video card or the motherboard. In cases like this I would suggest to get an inexpensive dedicated graphics card and try that.
To work on your computer and to understand any error codes that the Power LED flashes, use the Quick Setup & Getting Started Guide Page 10 shows the basic troubleshooting for your computer. The other manual you want to look at is the Service Reference Guide HP DC 5700 This one will show you how to do some of the repairs.
Translation
@hectorcede40839 primero necesitamos saber como sabes que se ha encendido. Dinos qué hace el LED de encendido. Una vez que te has asegurado de que está encendido pero no muestra nada, necesitamos saber si estás usando una tarjeta de vídeo dedicada o si estás usando la tarjeta de vídeo integrada en la placa base. Dinos cuánta memoria tiene tu ordenador y qué has comprobado. Necesitamos saber si está seguro de que el monitor funciona y qué modelo exacto tiene.
Si su ordenador se enciende y funciona correctamente, entonces el problema es la salida de vídeo (si el monitor funciona). Podría ser un problema de la tarjeta de vídeo o de la placa base. En casos como este yo sugeriría conseguir una tarjeta gráfica dedicada barata y probar eso.
Para trabajar en su ordenador y entender los códigos de error que parpadea el LED de encendido, utilice el Quick Setup & Getting Started Guide Página 10 muestra la solución de problemas básicos para su equipo. El otro manual que quieres mirar es el Service Reference Guide HP DC 5700 Este te mostrará cómo hacer algunas de las reparaciones.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 41
