The iRobot Roomba i7 is a robot vacuum which features dual spinning rubber brushes for maximum efficiency, cleaning pet hair and multi-surface floors.
9 Questions View all
New battery doesn’t charge up to 100%
I bought new battery from the iFixit store but even leaving it charging for a whole night it never reaches 100%.
I followed the instructions to mount it, holding the robot's buttons before inserting the new battery.
To be on the sure I did an hard reset of the robot but the battery does not fully charge.
Score 1
Add a comment
Chosen Solution
@matteo80904 try what iFixit recommends: For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Now if you continue to have issues with the battery, I would suggest you contact iFixit. Since you bought the battery on iFixit, contact the service department: eustore@ifixit.com or support@ifixit.com and let's see if they can help you further :-)
4 Comments:
I’ve tried using the robot until it shut off but when it’s low battery it goes automatically to charging base. Any suggestions on how to fully discharge?
by
@matteo80904 have you tried to disconnect the base so the robot can’t find it or it doesn’t charge
by
@oldturkey03 thanks, it took 3 hours(new battery brought big improvement) but the robot got fully discharged and now the battery has reached 100%.
by
@matteo80904 Awesome! Repair is War on Entropy!
by
Add a comment
Im having issues with 2 different (both realtivly new) J7s i assume internals are the same as the i7 but both of them have intermittant charging issues where they both wont charge but after rebooting them they charge. should i try this method as well? to run it all the way then charge them?
Add a comment
Add your answer
Matteo will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 11
All Time: 267
