The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
634 Questions View all
Lid not closing all the way
Hi,
About a week ago the lid started not being able to close all the way (it started with one side not touching and then both). I assumed it was a battery swelling problem because this has happened once before, so I removed the battery. But unlike my first battery problem, the lid still couldn't close even without the battery inside.
A couple days later the lid still can't close so I assumed it might be a hinge problem. Waited a week for tools to ship, then tested out the hinges. The hinges were tight, so I took out all the screws and the lid was finally able to close. I put the screws back in one by one, and it turns out that tightening any of the three screws on the right side too much caused the lid to rise.
I tightened them as much as I could without causing deformity, reassembled the laptop back together, everything looked good, and the lid closed properly. But when I opened it there was a small cracking sound (coming from where the right hinges were), and when I tried to close the lid it returned to the original problem. I repeated the same thing, fixing all the hinge screws again and the laptop easily closed. Right now it's staying closed just fine but I haven't tried opening it.
This seems like something's wrong with the screws but I'm not sure what to do. (I do wonder if waiting a week for tools allowed for even more warping to occur.) Does anyone have any advice or experience with this?
Thanks.
Score 1
Add a comment
Did the hinge look damaged
Add a comment
Can you explain a bit more here on what the lid is doing. Maybe posting a few pics might help.
From your description it’s hard to tell what needs fixing.
Add a comment
Add your answer
Nat will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 45
All Time: 117
