Released in November 2020, the 13" MacBook Pro features Apple's Arm-based M1 SoC with both an 8-core CPU and 8-core GPU. (Model A2338 / EMC 3578 with two Thunderbolt 3 ports)
116 Questions View all
M1 MBP went from having a bad battery, to switching off after login.
I had my MacBook Pro 13" Two Thunderbolt Ports Late 2020 repaired by someone in my area following a water damage incident. I'm guessing the replaced battery was dodgy.
Everything worked fine following the replacement, however after a while I started to notice the battery life start to drain quicker and quicker, then degrading even more to only lasting a few seconds without being plugged in with the USB-C cable that came with it.
Then, it started shutting off after a few seconds past the login screen. I would put my password in, see my homescreen, then black screen, then the bootup Apple logo.
My assumption is that, even while plugged in, the battery can't provide enough power to the system and shuts off, but I'm certainly not well versed when it comes to MacBook internals.
I've had to stop using the laptop, but would replacing the battery fix this issue of crashing after the login screen? I'm happy to provide a video of this or provide any additional information if required! Thanks :)
Add a comment
1 Answer
If you can install this App CoconutBattery take a snapshot of the Apps main window and post it here so we can see what’s happening while the charger is plugged in.
2 Comments:
Since the macbook shuts off a few seconds after logging in, I don't think it would be possible to install or run CoconutBattery :/
by
@neky - At this point your only option is to replace the battery with a fresh one and before it runs out of power take that snapshot.
Some how you need to discover if the system is charging at all and at the correct rate or if the battery has failed.
by
Add a comment
Add your answer
Neky will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 35
