Where did this spring come from, and how can I put it back?
This printer was having paper jam after paper jam. I would simply open the back and pull the sheet out as instructed, but the last time it jammed, the paper was too stuck and tore. My dad ended up getting it out (turns out there's still a tiny bit left in there: any tips?), but as he did so, this spring came out. He says he didn't unscrew anything, but the back was open and at some point he accessed the underside (above the tray).
Photos below. Thanks in advance to anyone who can (or tries to) help!
Update (02/12/24)
Update: an identical spring came loose and I grabbed it. It came from maybe 6 inches deep. There's a plastic piece 2-2.5 inches wide that is now loose, which can be pushed up on both sides. I can't get my phone camera to focus that deep, but I have a picture of a prying tool lying passively under it and then another of it pushed up, where you can now see some light:
So we're going to try to take the printer apart.
Second Update:
It was indeed Paper Guide Upper Right.
Unfortunately, poor little Paper Guide Upper Right is broken:
Bonus image of the culprit:
Big thanks again to @oldturkey03! My hero.
Score 1
Add a comment
1 Answer
Chosen Solution
@luke36264 going by the general location I wonder if those are the paper guide springs.
what do you think? Could be, right ;-) Anyhow, this Epson ET 3760 SM should help you with working on your printer and replacing those springs. Use the search function of your PDF reader and type in Spring and you'll be surprised how many it'll find :-)
Repair is War on Entropy!
Score 2
2 Comments:
I'm new to iFixIt. Can I not directly reply to @oldturkey03? Anyway, thank you! That looks exactly right. Also, thanks for the PDF! I know what I'm doing this snow day.
Edit: Oh, I thought I was commenting on the entire post. lol
by
@luke36264 you did contact me directly; you used the @ username so I got notified :-) Sort of like the Bat-Signal here :-)) Best of luck to you and we hope you get your printer back on the road quickly. Welcome to iFixit!
by
Add a comment
Add your answer
Luke will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 42
All Time: 175
