Repair and disassembly information for the Logitech MX Anywhere 3 portable wireless mouse. Released in 2020 and identified by model number 910-005986, 910-005833, 910-005987, or 910-005985.
3 Questions View all
phantom clicking in Anywhere MX 3
Same problem addressed for Anywhere MX mouse, but since this model is different, I wonder if there's another solution.
This happened after around 1.5 years of use.
My partner has the same mouse and the same problem, using a different OS, so it seems to me to be a hardware problem.
Score 1
3 Comments
Hi @glicerico
What had you tried? had you tried replacing the micro switch?
by
No, I don't know what the micro switch is or how to replace it. Is there a guide? If you are referring to the article I linked, I planned to do it, but saw in the comments that some people tried with the Anywhere MX 3 and didn't work for them
by
Ah, I think the micro switch is the module containing the clickable part. No, I didn't replace that, I don't have the spare part.
by
Add a comment
Chosen Solution
Inspired in the guide for the Anywhere MX mouse, I opened the Anywhere MX 3, and although it's not built the same way, the solution was simple.
After carefully removing the 4 pads in the bottom of the mouse, then the 4 screws below them, I opened the mouse and saw the white elongated button responsible for the click.
I cut 3 small squares of black electrical tape
to fit the contact point with the click button on the other side, on the top of the mouse. I pasted the 3 squares one on top of the other in the place indicated by the screwdriver:
then just reassembled the mouse cover, screws, and pads.
This fixed the problem and now my mouse works as good as new :)
Add a comment
Yep. Same double click issue as all other Anywhere MX, appeared after 2 years of use after mandatory warranty ran out. Starting to believe this is deliberate design flaw. Has happened in 5/5 Anywhere MX mouses I have used.
1 Comment:
sad situation
by
Add a comment
Add your answer
glicerico will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 30
All Time: 158
