Microsoft's third-generation Xbox game console, released November 22, 2013.
730 Questions View all
What could be causing this On/off, on/off, on/off cycle?
As soon as I plug in the power cord, the xbox WANTS to turn on, but only gets power for a split second and shuts off. It will stay in this loop for as long as I keep it plugged in. The fan moves a tiny bit and you can hear a small click from the processor, but then nothing. The power brick turns green for a split second as well and then back to off. This cycle keeps repeating until I unplug the console.
Any Ideas what could be causing this?
Score 1
2 Comments:
@garymdobis Have you tried a different power brick?
by
No I haven't, that makes a lot of sense though. I bought the console from a "friend" and he told me it just needed a power brick. I bought a knock off from Ebay. I have the xbox torn down to just the motherboard as of right now and even with everything removed, when I plug the power brick in, it cycles.
by
Add a comment
1 Answer
For your problem I think you're power button is not correctly installed it's an easy fix, the first step is to take your Xbox apart then the front of the Xbox has a ribbon cable and that front ribbon cable might not correctly installed when my Xbox was working it had a similar problem. But now it's toast so I need to get it looked at by a professional. But yes I would try to see if it is the ribbon cable.
Add a comment
Add your answer
Gary M Dobis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 36
