Available. Released 2019, March 07 IPS LCD - 6.26 inches Resolution - 720 x 1520 pixels OS - Android 8.1 (Oreo), EMUI 8.2 Chipset - Qualcomm SDM450 Snapdragon 450 (14 nm)
17 Questions View all
Water damaged phone need to fix
So I dropped my phone in water and has been damaged, it won't turn on or anything, so I opened it up dried as much as I could. I then cleaned any corrosion using isopropyl alcohol from the connection ports. I put everything together and now when I plug in my charger to the phone it keeps vibrating every second. If I disconnect my battery the red charging LED comes up, but not when I reconnect the battery. Any idea what the issue could be?
Score 2
Add a comment
1 Answer
Most Helpful Answer
@sajidtalati you said you cleaned any corrosion "from the connection ports" but you are not saying if you cleaned all the boards. You do need to remove the EMI shields from your boards. If you do not remove the shields, you are not cleaning the board.
Once you got the shields and the boards removed, clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning.
In your case, I would probably not clean the sub_board (charging board) but I would replace it. The boards are relatively inexpensive and by replacing it, you eliminate any issues with that. Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now.
After that, reassemble your phone and re-evaluate. For as long as you have not cleaned your board properly and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
You also need to keep in mind that it is possible that your display has been shorted out. You may have to replace the display assembly as well.
Huawei Y7 2019 Charging Board Replacement
iPhone Image
Guide
Repairing iPhone Liquid Damage
Difficulty:
Difficult
1 - 2 hours
Huawei Y7 2019 Charging Board Image
Guide
Difficulty:
Easy
10 minutes
Score 1
Add a comment
Add your answer
Sajid Talati will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 25
All Time: 92
