The original Motorola One, not to be confused with the One Power or One Action. Model number XT1941.
15 Questions View all
White light blinking at the side of the frontal speaker when charging
After my phone got wet, I let a long time letting it dry (not on rice don't worry). But after that happened, when I try to start my phone, it doesn't start, and when I try to charge it, at the side of the frontal speaker a white light blinks.
I sent it to a repair shop but they gave me a high cost to fix it (as always). I declined to try to repair it by myself. What should I check for in my phone? And what I might have to change? Thanks!
Add a comment
1 Answer
Chosen Solution
You need to open the critter and check for and clean any corrosion, if you are lucky, that will set things right:
We don't have a tear-down on this device, so I'm putting a You-Tube video link below showing you how to disassemble and clean it. Word of advice, use a soft-bristled toothbrush and do not be very forceful; the SMDs (the tiny Surface Mount Devices) are easily damaged if you get carried away... be gentle. Since we don't have a tear-down on your device you might want o take photos of the process and add them as a guide for others with the same problem. Here's the video link:
https://youtu.be/dLqu45I8j1E
Good Luck. Let us know if we helped you!
Score 1
2 Comments:
Is there another one for my specific model? Because this video is from a model that opens from the screen, and my phone has been already opened (well the glass was shattered anyway) from the back...
Edit: Nevermind, these steps are quite simple, I'll just get them going. Thanks!
by
You're quite welcome. Good Luck!
by
Add a comment
Add your answer
Adrian Zurita Rasgado will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 64
