A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
171 Questions View all
My pc keeps overheating on startup
It hasnt been like this in the first 2 months. But all of a sudden my pc whenever i turn it on, it starts normally and with no applications being opened or anything, the cpu temp just keeps rising untill it reaches 115 Celsius and then it shuts down. Usually i just turn it on, see its overheating, and turn it off and continue the cycle untill it decides to not overheat on startup. I turned of all of the startup applications and im sure that my coolers pump works. But it still keeps overheating.
My pc specs are:
4x16gb 3200mhz kingston ram
Nvidia 3060ti 8gb vram
Ryzen 7 5700x cpu
Asus b550 aorus elite motherboard
My power supply is asus bronze 750w
And cooling system is lc power lc-cc-240-LiCo
If anyone can help me fix this it would be amazing, thank you in advance.
Score 2
1 Comment
I checked the mounting and the thermalpaste, its all good and nothing is missing/lacking. Im not sure if there is a problem with something forcing the cpu to overheat itself. I checked the voltage and its 1.1 so its fine
by
Add a comment
Most Helpful Answer
If possible check that your CPU cooler is seated properly. The rapid temperature rise could be due to Poor contact with the CPU IHS(integrated heat spreader). There is a chance that your mounting hardware may have come loose.
Score 2
Add a comment
@petarvelickovic
Try getting into the BIOS menus on startup before it boots into Windows and check if the problem occurs.
If it doesn't then try starting in safe mode (see Method #2) and check if the problem occurs.
If it doesn't happen in either situation mentioned above then it looks like it is software related and not a hardware problem.
Have you checked Task Manager → Startup to see what programs are loaded on Startup?
Try disabling them one at a time and then starting the PC after each one has been disabled and check if the problem still occurs.
Score 1
Add a comment
Well you can try the following:
  1. Position your computer in the correct place.
  2. Close your system's case.
  3. Maintain your fans.
  4. Upgrade to a water-cooling kit.
  5. Optimize your PC or laptop settings.
  6. Keep your software updated.
  7. Shut down your computer.
1 Comment:
Everything listed is being done for a long time now. The pc's positioned on my desk with alot of free space around it. I clean my fans and the inisde of the pc every month. I check for software updates every week. And my cooler is a water cooling system that i bought from a pc shop. The pc is usually on for around 5 hours a day.
by
Add a comment
Add your answer
Petar Velickovic will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 15
Past 30 Days: 74
All Time: 873
