The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1198 Questions View all
Intermittent display glitches (moving horizontal lines)
My display started to glitch recently.
Mostly horizontal lines moving up and down (almost like scan lines when you record a cathode ray screen).
The horizontal lines often show a previous version of what was visible on screen. I.e. when I lock the screen the glitchy lines show the previous desktop for many seconds.
It happens 90% of the time, but sometimes it still works flawlessly.
And the display switches between "working good" and "glitchy" without me touching anything every few minutes.
External monitor with mirroring works as well.
What is broken here?
Update (03/12/24)
It's been working for two weeks now without any problems without me doing anything. I've had the horizontal lines appear once all of a sudden. I turned the screen off by locking it, waited 10 seconds, turned the screen back on. Slight brightness flicker for a few seconds, then everything worked flawlessly again.
Even when horizontal lines were flickering a lot two weeks ago, a brief "screen off, wait 10 seconds, screen on" maneuver brought back a normally working display at least for a few seconds.
For completeness: This is the green color shift that happens from time to time and slowly vanishes over the course of ~20 mins.
To be honest, this smells to me like a broken capacitor that's coming back to life from time to time.
Anyways, I got an Apple Silicon Macbook so in case it breaks again, I am all set.
Add a comment
More than likely your graphics card is messed up; If you see the lines on the external display.
So, try reseting the NVRAM and SMC first. And run Apple Diagnostics as well.
6 Comments:
@jadonlyon - If the external is clear (as it is here) that’s a bad internal display assembly.
by
@danj - Yes, exactly. I cannot tell in the picture if it clear or not.
by
@jadonlyon - The two screens are showing the same image. the external on the left is offering a spotless image only the internal displays image is messed up.
by
@danj - Okay, I see that. Yes, the internal display is probably messed up.
@clemens29917 - I would suggest running Apple Diagnostics to see if you can diagnose the problem. (Apple Diagnostics doesn't always show exact issues, but it can gave you a head start!)
by
@jadonlyon - Apple diags won’t test the display only the graphics engine, which it’s clear is working on the external.
by
Show 1 more comment
Add a comment
Sadly, the internal display has a scanning issue often happens when the signal lines are damaged within the panel interface. Did you give the system a bang or sit something heavy on the lid? Thats the more common cause.
Here’s the needed part MacBook Pro 13" Retina (Early 2015) Display Assembly post a note to the store to let you know when it’s available. If you can tell me where you live country wise I might have a closer source for the part. In any case here’s the guide MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement
MacBook Pro 13" Retina (Early 2015) Display Assembly Image
Product
$449.99
4 Comments:
It fell around 40cm from the edge of the bed, then kept working for another ~4 days. Then the glitches started to happen.
As of now there is a period of ~2h where there were no glitches at all.
(Also, the external display is always fine.)
I am from Germany.
I still wonder why it only glitches sometimes. I was hoping that there is some part inside the display that could be brought back to life with a heat gun or something :(
by
@clemens29917 - Sadly, these older displays are getting hard to find in good condition. Even still people are having a hard time letting them go! Even I have a firm grasp on my two 2015 15” systems too!
The best source other than iFixit on your side of the pond is TheBookYard in the UK, the only one they have right now is this one MacBook Pro 13" Complete Display (15) - Staingate Removed : Grade-B
Issues like yours where it comes and goes is when micro fractures within the panels back plate occurs. The back side has all of the metal oxide traces which are invisible to the eye but are easy to damage when the glass encounters too much stress. Just like a loose light bulb in the ceiling will flicker when someone walks across about above.
by
Thanks for your help. PRAM and SMC reset did nothing, as expected. Yesterday everything was working without any glitch for hours. I go to bed, come back the next morning, activate the screen and the glitches are back. I don't see any reaction of the glitches to mechanical stress. It just seems to appear/go away completely random. It pressed everywhere on the screen, even twisted it. Bobbed the hinge. Banged the device on the desk. No reaction.
I will try the mechanical-stress-thing again next time when everything works fine.
Another interesting observation: Different glitches seem to appear: sometimes the scanning horizontal lines, sometimes a green glow that fades to the edges and over the course of half an hour slowly fades more and more until it is completely gone.
Anyways, 135€ for the used replacement seems like an okay deal.
by
@clemens29917 - Sounds like your on your way! Don’t forget to score the answer and accept it ir you’re set - Thanks!
by
Add a comment
Add your answer
Clemens will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 83
