A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
214 Questions View all
What would cause my Bravo washer to not spin the clothes in a cycle
What would cause my Bravo washer to not spin the clothes in a cycle yet when the dial is turned to drain/spin it works. The clothes spin forever like the brake doesn’t engage.
Update (02/23/24)
MUWX700XL2
BravoX
Add a comment
1 Answer
Most Helpful Answer
Hi @marshallbr61156
Did you mean MVWX700XL2?
If so here's the tech sheet for the washer that may help to find out what the problem is.
Go to p.2 to view the procedure for entering the diagnostic test mode and check if any error codes are shown during the tests. - see Activating the service diagnostic test modes.
To interpret the status LEDs to know what the code is, see the Fault/Error Code Display Method chart on p.3
A description of the each code and the possible checks are shown on p.6→p.7
If there is a faulty part and it needs replacing, here's a parts list that is useful.
Scroll through the list to locate the wanted part and once it is found you will find the manufacturer's part number for the part listed with it. Search online using the part number only, to find suppliers that suit you best.
Score 1
4 Comments:
This is copied straight from
The label. It’s not MVW. MUW
MAYTAG
6.0
120
® Trademark ol/Merque Déposta de Wnlripool, U.S.A,
AMPS
VOLTS
60
Hz
Benton Harbor, MI. 49022
Whiripool Canada, Liceneee / Emplol Licenció au Canada
TYPE: 588-04
MOD MUWX700XL2
SER
C23931825
C
US LISTEN
Wat
0%/,1001142 0 Lovor 1154
ALE L12.77
Energy Vortfied
Only
184186
by
@marshallbr61156
OK but there's no results at all when searching online for your model number i.e. no parts, user manual, tech sheet etc.
I was looking also at Maytag/Whirlpool parts suppliers in Canada and they either came up blank or had links to MVWX700XL2 parts.
You could try the tech sheet I linked just in case it is also relevant to your model.
by
@marshallbr61156 post a picture of the label with your Question. I just checked your serial number as well and even that comes back as a MVW ;-)
by
I believe I got it diagnosed as the actuator. I found my manual and read up on it. I can’t seem to post pictures, but my above comment includes the serial number.
by
Add a comment
Add your answer
Marshall Brown will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 46
