Repair and disassembly information for Samsung's S22 smartphone, released in February 2022.
33 Questions View all
No cellular connection after replacing battery and charging port
I recently replaced the battery and charging port on my Samsung S22. Both seem to work fine, however I no longer get any cellular signal. I've double checked that all of the connectors are properly seated and reset the network settings without any luck. Any ideas?
Add a comment
Chosen Solution
@oldturkey03
Turns out, the new charging board was damaged on arrival. I swapped the old one back in and the mobile data started working again. I guess I'll keep living with a finicky charger port until I can get a new part in.
(It's not a 5G phone btw)
Score 1
1 Comment:
@benjaminbashor Great. Glad you figured it out and got it working again.
by
Add a comment
Most Helpful Answer
@benjaminbashor double check your work. Remember that your main antenna on a plastic cover on the top. Make sure that everything has been put together again. You are not telling us if you have a 5G, those antennas are in a different place.
Score 1
Add a comment
Add your answer
Benjamin Bashor will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 70
All Time: 1,114
