Apple's mainstream 2020 iPhone was released October 23rd and comes with a 6.1" OLED display, a dual 12 MP camera system, and in five available colors. Successor to the iPhone 11.
173 Questions View all
iPhone 12 battery at 1% / not charging after replacement, old works
I'm trying to replace the battery on my iphone 12. The original battery works fine but had been used heavily and wasn't lasting as long as it used to.
I installed the replacement battery (from ifixit), but the phone shows up as 1% and there is no "lightning bolt" charge icon when the phone is plugged in. The battery menu in settings shows the phone as charging during periods when I leave it plugged in though. The phone locks and reboots periodically while plugged in, and 0% remaining" is displayed on the lock screen.
I saw other threads online with similar symptoms from different model iphones that indicated that I might have damaged surrounding components or circuitry. I took me a bit to get the new battery connector installed, but I did not see any loose pieces or visible connector damage on the phone.
I decided to test this by disconnecting the new battery and reconnecting the old battery. If the circuitry was damaged, I would expect both batteries to fail, however the old battery reports percentage, charges and the phone seems to operate fine when its installed.
I've tried reconnecting the two different batteries several times, and have tested with the screen on and off to try and rule out shorts as a possible cause.
The ifixit battery shows 3.78V on a multimeter when measured at the connector, while the original battery shows 3.8V (battery is rated at 3.83V). I inspected the connector on the new battery and can't see any obvious damage.
  • Any ideas on possible causes?
  • Next steps to debug?
  • Is it possible that there is an issue with the new battery?
Add a comment
1 Answer
Chosen Solution
Hi Zac,
You've done pretty much all the debugging I would have given the same situation, and my conclusion would be that there's something going on with the replacement battery. Although in my experience iFixit does their best to provide top quality parts, it's just a fact of life that sometimes a bad apple will slip through.
So I'd suggest you get in touch with the iFixit Store personnel and discuss the issue you're having, along with what you've done to debug it. Their batteries have a 1 year warranty and the company was very responsive the one time I had a battery issue, so email them at support@ifixit.com and I'm sure they'll get you fixed right up.
Score 3
1 Comment:
Thanks for the reply & info. I got a magnifying glass and inspected the battery connector and I can't see anything wrong with it. Tried reseating it again and still no improvement.
I'll reach out to support to figure out next steps.
by
Add a comment
Add your answer
Zac will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 63
All Time: 155
