Cellular version of Apple's 2nd generation iPad Air. Model A1567.
88 Questions View all
anyone know what it is for? for ipad air 2 cellular?
ANYONE KNOW WHAT IT IS FOR? FOR IPAD AIR 2 CELLULAR?ANYONE KNOW WHAT IT IS FOR? FOR IPAD AIR 2 CELLULAR?
I fixed ipad air 2 lcd screen
Accidentally I broke the antenna things
you can see the pictures
luckily still wifi and cellular are working thank god
I'm very curios what is this antenna for?
plz let me know thanks
Add a comment
1 Answer
I'm not 100% sure but those do not seem to be antennas. I very well may be wrong, but that looks like EM shielding made to protect the logic board from interference.
2 Comments:
Thanks for replying if u go wire things all the way there is antenna things at corner link together can u see? It looks same as ipad 5 and 6
by
You are right. Upon closer inspection I have realized what you mean.
The damaged IPEX cable can be replaced for cheap if you know how to solder, but the EMI resistance will be reduced and you will probably suffer more interference. If that bothers you, you can probably source a replacement from an online store or a broken donor iPad.
I am not sure what the broken antenna might do, but I believe it is responsible for 4G LTE MIMO (Multiple In, Multiple Out) for higher speeds. It is not vital for basic functioning, but it may significantly damage your network speeds.
by
Add a comment
Add your answer
Kyuho Lee will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 36
