Hyundai's entry-level vehicle. It's available only as a sedan; the hatchback was discontinued after the 2017 model year.
19 Questions View all
P0730 Gear ratio incorrect (pulley)
Hi I have a Hyundai accent to this is your card
front of me it's P0730 in gear my gear type is CVT and I don't know how can I fix it if anyone know I'll come and fix it say please do I answer this question
Add a comment
1 Answer
A logged P0730 code is a trouble code that indicates the transmission is slipping. The powertrain control module registers this code when there's a greater RPM difference between the rotational speed of the input RPM and the transmission output of the RPM sensor.
I would test the speed sensor and check the transmission fluid level first and foremost. This is an indicator of a failing transmission.
Cheers
Monte
Add a comment
Add your answer
AL MONSTER will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 70
All Time: 163
