Repair information and disassembly guides for wireless Xbox One and Xbox Series X|S controllers.
520 Questions View all
Xbox One Wireless Controller (Lunar White) working only with USB cable
My Xbox controller will not work without a direct USB connection to a console. Tried new batts, software updates, and all I got it to do was make it turn on for .5 seconds. Any solutions? Also turns on console.
Score 1
Add a comment
Most Helpful Answer
If the controller turns on and stays on when connected to the console as well as works as normal, I have found that the Bluetooth chip on the controller can cause it to power off when it goes bad or gets shorted.
Score 1
Add a comment
Hello, same problem but i fixed it
The console's Pair button on the controler may be broken, to fix it you might need to replace the button
2 Comments:
It is still paired to the console, but only can turn it on, then die.
by
oh, then sorry, i cant help you anymore😔
by
Add a comment
Add your answer
Calvin Hoops will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 57
