Apple's mainstream 2020 iPhone was released October 23rd and comes with a 6.1" OLED display, a dual 12 MP camera system, and in five available colors. Successor to the iPhone 11.
173 Questions View all
Dim screen after replacing with LCD
I replaced my screen on my iPhone 12 with an LCD and after I replaced it turned on with the Apple logo and it seemed bright and fine but when it goes onto the Lock Screen it was super dim so I tried to turn up the brightness and it didn’t fix it but instead it stayed dim. Why was it bright while turning on but now it’s dim and I can’t change the brightness?
Add a comment
1 Answer
Most Helpful Answer
I'm willing to bet this is related to the ambient light sensor. It's an issue I have seen myself with the iPhone 12. If the Ambient Light senor isn't working properly this is exactly the behavior you'll get. Apple logo is maximum brightness, because it's always maximum brightness. But once the lock screen shows, the ambient light sensor kicks in. If it's not working properly, then the screen will always be at minimum brightness.
Did you transfer the sensor/receiver speaker cable from the old screen? If so those cables are very delicate and it's possible it was damaged. It could even have been damaged beforehand if the old screen was damaged in that area. I could give it a good inspection. The iFixit Guide even calls this out in this step of the screen replacement guide.
If the new screen came with a new sensor cable, it could just be that the ambient light sensor is a dud.
Score 1
Add a comment
Add your answer
Nathan Williams will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 32
