A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
569 Questions View all
MacBook will not stay on with new battery
I bought a new battery for my MacBook from iFixit, installed it following the guide. But now the MacBook will not turn on when not connected to a power supply. When I try to turn on my MacBook while plugged in, it shows me that the battery is at 0% and not charging. I get to the login screen but a second after logging in, the screen goes black and will not turn on again.
I assumed that either the battery is faulty or I made a mistake installing it. I double checked that all connectors are properly plugged in. Then I disconnected the battery and booted up the MacBook while plugged in with no battery. This time I didn’t get the black screen and everything worked fine.
I noticed that when the screen went to black before, coconut battery had launched and actually recognized the new battery! It now shows up in the history with 105% capacity.
So… it seems like my laptop did recognize the battery but still couldn’t use it? I am at a loss. I already tried an SMC reset which didn’t help.
Add a comment
1 Answer
Chosen Solution
Check the battery boards data cable connection. Reference Steps 10 ~ 13 in the MacBook Pro 13" Function Keys 2017 Battery Replacement guide. Often I find the ZIF latches are not folded down to compress the cable or it’s missing! As it flew off when you unlatched it or broke things.
I would install this Gem of an App CoconutBattery it will offer useful info to diagnose things. Post a snapshot of the apps main window here for us to see.
Score 1
5 Comments:
Everything is in place with the latches secured.
The computer doesn’t stay on long enough to take a coconut screenshot when the battery is connected.
One other thing I noticed is that when I’m on the login screen the battery percentage changes occasionally: it‘s at 0% most of the time, then suddenly jumps to 49%, then back to 0% after 1 second.
This also made me think there’s a loose connection somewhere. But I also tried to reconnect the old battery which worked fine. When I went back to the new one, same problem as before
by
@aajwu - You’ll need to get a replacement from the store as it does sound like a bad battery.
by
Thank you! Will do that
by
@aajwu - If you're set for now, please score and accept the answer - Thanks!
Do let us know how it goes!
by
I got a replacement battery today and now the laptop works like a charm. Thanks so much for the advice!
by
Add a comment
Add your answer
Alex W will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 64
