Essentially, the Xperia 1 II is a more powerful version of the Xperia 1. 'Nuff said.
2 Questions View all
mobile radio which is turned off ... trying to turn it ..doesn't do an
I have a similar problem with the mobile radio which is turned off and trying to turn it on through the service menu (*#*#4636#*#*) doesn't do anything and the change doesn't save anyway as when you go back in the menu the mobile radio is off again.
Interestingly the fingerprint scanner, volume key and camera key have also stopped working and have read on a post of someone with the same mobile radio problem who, after opening the phone, found a problem a cable involving the mobile radio and fingerprint scanner that had come loose and reconnecting it solved his problem.
Any ideas on if this might be the problem or what it could be? I've tried factory reset, Xperia companion repair etc.
Score 1
Add a comment
1 Answer
I would start with opening it to check for this issue if nothing else has worked so far.
Add a comment
Add your answer
Rashed Aslam will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 37
All Time: 81
