Released in 2018, the Lenovo IdeaPad 330 is part of the IdeaPad 300 series, a class of home and office PCs.
7 Questions View all
Determining which one of the sub-models I own.
There are ten submodels of this machine. My sticker was rubbed off many moons ago. Used the machine in the rain. Motherboard is damaged. I removed the solid state hard drive and docked it. Works fine. Now, I would like to replace the motherboard. Cannot find numbers on the board that match Lenovo part numbers.
1 Comment
@edward78879 I believe Lenovo used a lot of Compal logic boards. Most common place for the motherboard number is on the top side. If you still have your board mounted inside your computer then you are only looking at the bottom side. Remove the board and post some good pictures of both, top and bottom, with your Question. That way we can try to assist you with finding a replacement. Or maybe even fix yours :-) It might just be NM-B451 or NM-B671 but we'll have to see
Adding images to an existing question
by
Add a comment
Most Helpful Answer
Hi @edward78879
Go to Control Panel → Administrative Tools → System Information → System Summary and in the right hand panel check what is shown for Baseboard Manufacturer, Product and Version.
To get to Control Panel, type control panel in the search box on the left side of the desktop Taskbar and click on the link
Score 1
1 Comment:
that will work. I am not a windows user ;)
by
Add a comment
Go to lenenvo and provide them with the serial number that is stamped into the motherboard, and ask them what model it is
Add a comment
Add your answer
Edward will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 56
