My printer panel is blank
Let's try to reset the Printer here as it helps in removing any stored static electricity from the Printer which might be causing these issues.
Let's run the HP Print and Scan Doctor, which helps in resolving common printing and scanning problems such as missing or corrupt print drivers, connectivity issues etc.
Use this link for details on using the HP Print and Scan doctor: https://hp.care/2JyaC93
If the issue persists, let's do a root uninstall and reinstall of the software:
Unplug any USB cable, if any, before doing this.
1.) In Windows, search for and open Programs and features
2.) Select your HP Printer
3.) Select Uninstall
4.) In Windows, search for and open Devices and printers
5.) In the Devices and Printers windows look for your HP printer. If you see it listed right-click on it and choose 'Delete' or 'Remove Device'
6.) Open up the run command with the "Windows key + R" key combo.
7.) Type printui.exe /s and click Ok. (Note: there is a space in between “printui.exe” and “/s”)
8.) Click on the "Drivers" tab
9.) Look for HP Printer driver. If you see it Click on it and click Remove at the bottom
10.) Select Ok
11.) Select Apply and Ok on the Print Server Properties windows
12.) Close Devices and Printers
13.) Open up the run command with the "Windows key + R" key combo.
14.) Type c:/programdata and click Ok. Go to Hewlett Packard folder, remove any printer related folders & files.
15.) Restart the computer.
Once done, please download and install the software from here:
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 45
Hi @sam31650,
Does the printer still work if you try to print or scan from a computer connected to the printer?
by jayeff
