The Acer Aspire 4520-5464 can be identified by its model number: LX.AJN0X.010. It was released in October of 2007, and came equipped with an AMD dual-core processor and a 14.1” screen.
3 Questions View all
Why my Aspire 4320 Series enters a command screen when turned on?
My Acer Aspire 4320 Series enters a command screen every time I turn it on and the following text repeats over and over:
Broadcom UNDI PXE-2.1 v9.4.5
Copyright (C) 2000-2006 Broadcom Corporation
Copyright (C) 1997-2000 Intel Corporation
All rights reserved
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting Broadcom PXE ROM.
Operating System not found
(I know this is the forum for the aspire 4520 but the 4320 forum doesn't exist yet)
Add a comment
1 Answer
Most Helpful Answer
Hi @ianpcampos
The message you're getting indicates that either the HDD has failed or the MBR (Master Boot Record) files on the drive have become corrupted so it cannot boot into the Operating System.
Start the laptop and try to get into the BIOS menus by pressing the F12 key rapidly a few times.
There is only a small window of opportunity to get into BIOS and it is usually when the manufacturer's splash screen logo is on the screen and before it goes to boot into the OS.
If you can get into BIOS check if the HDD is shown as being detected by the BIOS i.e. model number of HDD etc.
If it is being detected then hopefully it is only corrupted MBR files on the drive. If there's no HDD detected then most likely the drive has failed.
Score 1
Add a comment
Add your answer
Ian P. Campos will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 32
