How do I open the Theragun mini?
Something's loose inside and it's really starting to bug me... When I turn it on it sometimes work but mostly it won't turn on. my hypothesis is that piece is jamming the motor. Can someone help me??
2 Comments
did you manage to open the device without breaking it? I can't find the way to do it. If you have any picture or guide that help me, I would highly appreciate it :)
by SantiHP
@santihp Put it in a vise (gently, use cardboard), then place a heavy duty razor blade along the seam and smack it carefully with a small hammer. You need to break the glue seal- very tight. Working it, you'll eventually get a crack going and you can use screwdrivers to pry it open. The battery pack is daunting, however. Custom circuit board soldered to the top, trying to find a solution...
by Goofpod
