Repair and troubleshooting information for HP 15‑fc0000 series 15.6" laptops, a line first released in January 2023. Laptops in this series have model numbers beginning with 15-fc.
1 Questions View all
My HP 15-fc0037wm laptop won't turn on.
My HP 15-fc0037wm laptop won't turn on.  I have checked the power supply. I have replaced the battery. I have removed the battery, plugged in the power cord and held down the button down -- no results.  When I press the power button, the tiny light on the power button blinks once, then nothing. When connected to power, light next to the power outlet on the laptop is on. What am I missing?
2 Comments:
Hi @johnnyray,
Try disconnecting the power adapter, removing the battery and then press and hold the power button for 30 seconds and then release it. Reinstall the battery, reconnect the power adapter and then check if it turns on OK
by
Thanks, tried that, but didn't work.
by
Add a comment
1 Answer
Sounds like an internal problem. You have eliminated the battery and maybe the adapter. You need to verify the adapter plug has the specified voltage on it either by measurement or substitution.
Replacing the battery should have powered it on. Most batteries are shipped with at least 50% charge.
The blink of the button LED is telling me there is an internal short and the power module is disconnecting as soon as it detects that.
It could be anything, but a shorted CPU is not uncommon.
Add a comment
Add your answer
Johnny Ray will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 65
