Released in November 2020, the 13" MacBook Pro features Apple's Arm-based M1 SoC with both an 8-core CPU and 8-core GPU. (Model A2338 / EMC 3578 with two Thunderbolt 3 ports)
116 Questions View all
Trackpad and Keyboard not work
A2338, after sometimes trackpad and keyboard not work, and USB keyboard and mouse work all time,
changed UT360, UT301. Diode value dropped in PP1V85_S2_IPD from 443 to 200. then i will replace that both IC and again value increase. same repeat. any idea, what to do,
Add a comment
1 Answer
Did you replace the trackpad cable?
3 Comments:
yes new track pad cable and also new track pad.. both not working.
by
@vijaypatel017 - Sorry you’ve changed so much, I don’t know where to even start here. Rarely do I find my self changing our parts without a firm grasp of a diagnostic process that compelled me to change out parts which haven’t any physical damage or corrosion visible.
What is the history? Did this get liquid damage at some point. While you replaced the trackpad the keyboard or even keyboard cable may be bad.
by
thanks for reply,
Yes it has a liquid damage near charging circuit, also near track pad IC, and keyboard cable burn, so i have replace keyboard, then correct charging circuit , charging and discharging work ok, then i have also replace trackpad IC UT360 and UT301 also, and also nearby capacitor CT360, CT361, CT400, LT400, CT302, CT303.
and nearby CT302 and CT301 capacitor minor track damage, i have corrected and fix it.
after correcting trackpad and keyboard work sometime may be 5 to 6 hr, then both stop, but external mouse and keyboard work ok alltime.
and sorry for late reply.
by
Add a comment
Add your answer
Vijay Patel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 47
