Repair information and guides for the long-awaited refresh of the popular MacBook Air, featuring Intel's Core i5 processors, an updated Retina Display, and numerous other changes and updates that was released on November 7th, 2018.
150 Questions View all
MacBook not working after battery replacement
The keyboard and trackpad work fine on my laptop but when powering it on it takes ages to load, is super slow, and won’t open any applications. The backgrounds also appear completely grey. I double checked and it’s the right battery for my model.
I’ve reset the SMC and tried to boot into Apple diagnostics but after entering my wifi password it loaded infinitely. I need help asap.
1 Comment:
check if trackpad cable is connected properly. use iStat menus to check if you have some issue with temp sensors.
by
Add a comment
1 Answer
It sounds like the battery might not be fully connected. When connecting the battery to its socket on the logic board it can sometimes be difficult and require some force to fully insert it. The edge of the battery plug should be flush with its connector on the board. In my experience this is almost always the cause of such symptoms after a battery replacement on this model. Good luck!
Add a comment
Add your answer
A cat called Thunderstar7 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 48
