There is a wide range of Philips vacuum cleaners, with and without bags, with cyclones, as manual models, etc.
3 Questions View all
Cant find guides to open the vacuum head for cleaning.
Vacuum model: Phillips Aquatrio Pro
Hello.
I have tried to open the vacuum head to see the issue which is brushes not spinning. The issue is i cannot acces the 2 screws behind the vacuum head because of how they are positioned. I am asking if anyone has dealt with this model of vacuum and has succesfully repaired it? Also i tried removing the head from the stick but i dont have the confidence to do that without the fear of breaking it.
The addded pictures show which screws i tried to remove.
Kind regards.
Score 1
Add a comment
1 Answer
Chosen Solution
Hi @basicslove30984
Found this teardown video that may give you some ideas on how to disassemble it. It looks like it is the same model.
The closed captions (CC) language is in Russian so hopefully the video is all you need.
Score 2
1 Comment:
Wow thank you very much!! will try it out looks very promising. 😁
by
Add a comment
Add your answer
basicslovenianbacon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 60
