Why is it not charging?
When ever I plug in my superlight to charge it and take the charger out after a while it shows a red light and turns off a couple seconds later
This is usually one of two things,
The charge port, this can easily be ruled out by being able to use the mouse wired.
The battery, it may have degraded for various reasons however if the mouse indicates its charging when plugged in and when unplugged it dies, its most likely the battery is no longer able to hold a charge.
I have the same problem but when I plug the charger led is off. My mouse is off I canโt use it , already change the cable but do not match.. can you help me please? ๐
Past 24 Hours: 9
Past 7 Days: 63
Past 30 Days: 227
All Time: 650
