Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
588 Questions View all
Troubles with new battery
I have changed the battery for a new one, but it does not charge 100%. The charge remains at 99% and does not reach 100% so I cannot calibrate the battery. The magsafe connector gets quite hot. So I don't know if it's a problem.
I use WATTS to see the health of the battery, but it shows me values as if it were the old one, except battery charge at 99%.
I followed the battery replacement guide, so I don't know what could be wrong.
Update (04/05/24)
Here are from 3 differents are the same results with differents programs
Add a comment
1 Answer
Let’s use a better tool, I find this one is quite good CoconutBattery take a snapshot of the Apps main window posing it here so we can see.
1 Comment:
@andresmend79046 - Well the replacement battery is not healthy either! I would recommend you return it to get another or your money back. Its likely this battery is a remanufactured one where someone took the cells apart check the discrete cells and then put the better ones back together to create a new battery. What does the battery info button tell you for the deeper battery maker info?
by
Add a comment
Add your answer
Andres Mendoza will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 34
